Help pros not creating or building projects
Pros won’t create a new project or build a project. It keeps giving me this error:
    Traceback (most recent call last):
     File "C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\site-
    packages\cx_Freeze\initscripts\__startup__.py", line 14, in run
    File "C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\site-packages\cx_Freeze\initscripts\Console.py", line 26, in run
  File "pros/cli/main.py", line 36, in <module>
  File "D:\a\1\s\pros\cli\conductor.py", line 178, in <module>
  File "D:\a\1\s\pros\conductor\conductor.py", line 33, in __init__
  File "D:\a\1\s\pros\config\config.py", line 30, in __init__
  File "C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\site-packages\jsonpickle\unpickler.py", line 40, in decode
  File "C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\site-packages\jsonpickle\unpickler.py", line 145, in restore
  File "C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\site-packages\jsonpickle\unpickler.py", line 200, in _restore
  File "C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\site-packages\jsonpickle\unpickler.py", line 311, in _restore_object
  File "C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\site-packages\jsonpickle\unpickler.py", line 378, in _restore_object_instance
  File "C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\site-packages\jsonpickle\unpickler.py", line 440, in _restore_object_instance_variables
  File "C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\site-packages\jsonpickle\unpickler.py", line 445, in _restore_state
  File "C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\site-packages\jsonpickle\unpickler.py", line 502, in _restore_dict
  File "C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\site-packages\jsonpickle\unpickler.py", line 428, in _restore_object_instance_variables
  File "C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\site-packages\jsonpickle\unpickler.py", line 396, in _restore_from_dict
  File "C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\site-packages\jsonpickle\unpickler.py", line 221, in _restore_reduce
ValueError: not enough values to unpack (expected 5, got 2)
Did you solve your issue? I’m getting the same exact error when I run prosv5.
ok I figured it out: delete everything relate to pros in \AppData\Roaming
