Help. VEXcode Pro, write to SD card error
Hi forum, please help. I try to write log file to SD card for debugging. However, I got “memory permission error”.
I am aware that @jpearman had example using vex::brain::sdcard::savefile. I would like to learn if there is another way to do it.
Is it because vexos did not support stdio.
void usercontrol(void) {
  FILE * usd_file_write;
  usd_file_write=fopen("log.txt", "w");
	fprintf(usd_file_write, "/* log file for debug */");
	fclose(usd_file_write);
  int timeOld=Brain.timer(timeUnits::msec);
  int timeNew ;
  int deltaTime;
  while (1) {
    timeNew=Brain.timer(timeUnits::msec);
    deltaTime=timeNew-timeOld;
    FILE* usd_file_write = fopen("log.txt", "a");
    fprintf(usd_file_write, "wait(%d, msec)", deltaTime);
                    // prevent wasted resources.
stdio if supported, you probably have an issue with the SD card. The memory permission error will come from using a NULL FILE pointer. You should always test return value of fopen.
  if( usd_file_write ) {
  	fprintf(usd_file_write, "/* log file for debug */\n");
  int timeNew ;
  int deltaTime;
  while (1) {
      fprintf(usd_file_write, "wait(%d, msec)\n", deltaTime);
Thank you for your help. Here is the updated code and I did see that fopen failed. I use the same SD card with other codes and VEXOS can write to this SD card. I do not think it is SD card issue. And the brain recognized the SD card
Is there anything else I need to change? printf( "sdcard exist %d", Brain.SDcard.isInserted()); shows 1.
    printf("success\n");
  } else printf("fail\n");
  int timeNew ;
  int deltaTime;
  while (1) {
idk, I tried the code I posted and it works.
Thank you. It did work with another SD card (Samsung 128 GB PRO)!
The old card I used is Kingston 1GB and it works with std::ofstream ofs;, but not the code above.
As long as the SD card format is Fat32 it should not matter. Inside vexos, fopen, std::ofstream and sdcard. savefile all end up in exactly the same code.
