I am trying to program a toggle for our intake rollers, so I can just tap 5U, and they will stay on, rolling in, until I tap 5U again to stop them, or 5D to switch directions and roll out, and roll out until I tap 5D again to stop them.
I found a post by jpearman about toggles, and I tried to adapt it to have 3 different toggle states, but when I tested it, both toggle buttons toggled the intake on and off, except they both made the intake go the same direction.
Does anybody know what is wrong, or if there is a better way to code this?
Here is my code
int rollerMode = 0; // Start with the intake rollers OFF
int RBtn1Pressed = 0; // Intake roller IN button toggle
int RBtn2Pressed = 0; // Intake roller OUT button toggle
/* Intake Toggle and Controls */
if(vexRT[Btn5U] == 1) // Forwards
if(! RBtn1Pressed)
rollerMode = 1 - rollerMode; // change the toggle state
RBtn1Pressed = 1; // Note the button is pressed
else
RBtn1Pressed = 0; // the button is not pressed
if(vexRT[Btn5D] == 1) // Reverse
if(! RBtn2Pressed)
rollerMode = -rollerMode - 1; // change the toggle state
RBtn2Pressed = 1; // Note the button is pressed
else
RBtn2Pressed = 0; // the button is not pressed
if(rollerMode >= 1)
motor[roller] = 70;
if(rollerMode <= -1)
motor[roller] = -70;
else
motor[roller] = 0;
