Heres the whole code:
/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Frontleft motor 1
// leftarm motor 3
// Controller1 controller
// Inertial21 inertial 21
// rightarm motor 8
// Backleft motor 2
// Backright motor 9
// Frontright motor 10
// Piston digital_out A
// ClampArm motor 4
// Bumper bumper B
#include "vex.h"
using namespace vex;
competition Competition;
motor_group LeftSide(Frontleft, Backleft);
motor_group RightSide(Frontright, Backright);
motor_group arms(rightarm, leftarm);
smartdrive robotDrive(LeftSide, RightSide, Inertial21, 12.56, 16, 16, distanceUnits::in);
digital_out piston = Piston;
void DrivinG(int distance, int speed, directionType direction){
robotDrive.driveFor(direction, distance, distanceUnits::in, speed, velocityUnits::pct);
void Arm(int degrees, int speed){
arms.rotateFor(degrees, rotationUnits::deg, speed, velocityUnits::pct);
void pn(int value){
piston.set(!piston.value());
void turning(int angle, int speed, turnType turn){
robotDrive.turnFor(turn, angle, deg);
void Clamp(int degrees, int speed){
ClampArm.rotateFor(degrees, rotationUnits::deg, speed, velocityUnits::pct);
void BumpB(int speed, directionType direction){
//if bumper is not being pressed, hence the !
while(!Bumper.pressing()){
robotDrive.driveFor(direction, speed, velocityUnits::pct);
robotDrive.stop(brake);
int armsSpeed = 90;
int leftSpeed = 90;
int rightSpeed = 90;
int clampspeed = 100;
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton(void) {
vexcodeInit();
robotDrive.setTurnConstant(2.5);
robotDrive.setTurnThreshold(2.0);
Inertial21.calibrate();
robotDrive.setDriveVelocity(100, pct);
robotDrive.setTurnVelocity(100, pct);
robotDrive.setStopping(coast);
arms.setStopping(hold);
arms.resetRotation();
ClampArm.resetRotation();
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here.
void autonomous(void) {
Arm(65, 80);
BumpB(100);
pn(true);
DrivinG(20, 60, reverse);
wait(2, seconds);
turning(90, 53, left);
DrivinG(60, 65, fwd);
wait(2, seconds);
turning(45, 63, right);
DrivinG(35, 65, fwd);
pn(false);
DrivinG(10, 60, reverse);
wait(2, seconds);
DrivinG(20, 60, fwd);
pn(true);
wait(2, seconds);
DrivinG(40, 60, fwd);
wait(2, seconds);
DrivinG(50, 60, fwd);
Arm(95, 80);
wait(2, seconds);
turning(90, 63, right);
DrivinG(10, 60, fwd);
pn(false);
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
/* You must modify the code to add your own robot specific commands here. */
void usercontrol(void) {
while (1) {
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
LeftSide.spin(vex::directionType::fwd, (Controller1 .Axis1.value()) + Controller1.Axis3.value(), vex::velocityUnits::pct);
RightSide.spin(vex::directionType::fwd, (-Controller1 .Axis1.value()) + Controller1.Axis3.value(), vex::velocityUnits::pct);
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
if(Controller1.ButtonR1.pressing()){
arms.spin(vex::directionType::fwd, armsSpeed, vex::velocityUnits::pct);
else if(Controller1.ButtonR2.pressing()){
arms.spin(vex::directionType::rev, armsSpeed, vex::velocityUnits::pct);
else{
arms.stop(hold);
if(Controller1.ButtonUp.pressing()){
ClampArm.spin(vex::directionType::fwd, armsSpeed, vex::velocityUnits::pct);
else if(Controller1.ButtonDown.pressing()){
ClampArm.spin(vex::directionType::rev, armsSpeed, vex::velocityUnits::pct);
else{
ClampArm.stop(hold);
if (Controller1.ButtonL1.pressing()){
piston.set(true);
else {
piston.set(false);
// prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
edit: code tags fixed by moderators
