Can someone tell me what might be wrong with this code.
/** @file init.c
- @brief File for initialization code
- This file should contain the user initialize() function and any functions related to it.
- Copyright (c) 2011-2013, Purdue University ACM SIG BOTS.
- All rights reserved.
- Redistribution and use in source and binary forms, with or without
- modification, are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of Purdue University ACM SIG BOTS nor the
names of its contributors may be used to endorse or promote products
derived from this software without specific prior written permission.
- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS “AS IS” AND
- ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
- WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- DISCLAIMED. IN NO EVENT SHALL PURDUE UNIVERSITY ACM SIG BOTS BE LIABLE FOR ANY
- DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
- (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
- LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
- (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
- SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- Purdue Robotics OS contains FreeRTOS (http://www.freertos.org) whose source code may be
- obtained from FreeRTOS Real Time Kernel (RTOS) - Browse Files at SourceForge.net or on request.
#include “main.h”
- Runs pre-initialization code. This function will be started in kernel mode one time while the
- VEX Cortex is starting up. As the scheduler is still paused, most API functions will fail.
- The purpose of this function is solely to set the default pin modes (pinMode()) and port
- states (digitalWrite()) of limit switches, push buttons, and solenoids. It can also safely
- configure a UART port (usartOpen()) but cannot set up an LCD (lcdInit()).
void initializeIO() {
Runs user initialization code. This function will be started in its own task with the default
priority and stack size once when the robot is starting up. It is possible that the VEXnet
communication link may not be fully established at this time, so reading from the VEX
Joystick may fail.
This function should initialize most sensors (gyro, encoders, ultrasonics), LCDs, global
variables, and IMEs.
This function must exit relatively promptly, or the operatorControl() and autonomous() tasks
will not start. An autonomous mode selection menu like the pre_auton() in other environments
can be implemented in this task if desired.
void initialize() {
//Leave this value alone
int lcdScreenMin = 1;
//This keeps track of which program you want to run
int lcdScreen = 1;
//Change this value to be the maximum number of programs you want on the robot
int lcdScreenMax = 4;
lcdInit(uart1);
lcdSetBacklight(uart1, 1);while (isEnabled(0)) { //Ensures this code will run ONLY when the robot is disabled
if (lcdReadButtons(uart1 ) == 1) { //Scrolls to the left
if (lcdScreenMin == lcdScreen) {
lcdScreen = lcdScreenMax;
delay(250);
} else {
lcdScreen --;
delay(250);
if (lcdReadButtons(uart1 ) == 4) { //Scrolls to the right
if (lcdScreenMax == lcdScreen) {
lcdScreen = lcdScreenMin;
delay(250);
} else {
lcdScreen++;
delay(250);
if (lcdScreen == 1 && Program != 1) {
lcdPrint(uart1, 1, “1”); //Name the first program here
lcdPrint(uart1, 2, “1”); //Name the first program here
if (lcdReadButtons(uart1 ) == 2) {
Program = lcdScreen; //Sets the Program to the one on-screen
lcdPrint(uart1, 1, “Autonomous Has”);
lcdPrint(uart1, 2, “Been Selected!”);
delay(1500);
} else if (lcdScreen == 1 && Program == 1) {
lcdPrint(uart1, 1, “[1]”); //We use brackets to mark which program we have chosen
lcdPrint(uart1, 2, “[1]”); //So that while we’re scrolling, we can have one marked
} else if (lcdScreen == 2 && Program != 2) {
lcdPrint(uart1, 1, “2”); //Name the second program here
lcdPrint(uart1, 2, “2”); //Name the second program here
delay(1500);
} else if (lcdScreen == 2 && Program == 2) {
lcdPrint(uart1, 1, “[2]”); //We use brackets to mark which program we have chosen
lcdPrint(uart1, 2, “[2]”); //So that while we’re scrolling, we can have one marked
} else if (lcdScreen == 3 && Program != 3) {
lcdPrint(uart1, 1, “3”); //Name the third program here
lcdPrint(uart1, 2, “3”); //Name the third program here
delay(1500);
} else if (lcdScreen == 3 && Program == 3) {
lcdPrint(uart1, 1, “[3]”); //We use brackets to mark which program we have chosen
lcdPrint(uart1, 2, “[3]”); //So that while we’re scrolling, we can have one marked
} else if (lcdScreen == 4 && Program != 4) {
lcdPrint(uart1, 1, “4”); //Name the fourth program here
lcdPrint(uart1, 2, “4”); //Name the fourth program here
delay(1500);
} else if (lcdScreen == 4 && Program == 4) {
lcdPrint(uart1, 1, “[4]”); //We use brackets to mark which program we have chosen
lcdPrint(uart1, 2, “[4]”); //So that while we’re scrolling, we can have one marked
