Hello, I’m having some problems trying to make a custom six-motor drivetrain with the ability to be able to be called upon the same way as a regular drivetrain.driveFor
in Vex V5 so help would be appreciated.
void customDriveFor(double distance, int velocity) {
// Encoder is just the thing that lets me do .driveFor like with a normal drivetrain
int target = distance * 360 / (4 * 3.14159); // Wheel diameter is 4 inches
// Reset count for all motors
Motor1.setPosition(0, degrees);
Motor20.setPosition(0, degrees);
Motor11.setPosition(0, degrees);
Motor4.setPosition(0, degrees);
Motor5.setPosition(0, degrees);
Motor10.setPosition(0, degrees);
// Set motors velocity
Motor1.setVelocity(70, percent);
Motor20.setVelocity(70, percent);
Motor11.setVelocity(70, percent);
Motor4.setVelocity(70, percent);
Motor5.setVelocity(70, percent);
Motor10.setVelocity(70, percent);
// Start motors
Motor1.spin(forward);
Motor20.spin(forward);
Motor11.spin(forward);
Motor4.spin(forward);
Motor5.spin(forward);
Motor10.spin(forward);
// Checks if the encoder reached its target goal
while ((Motor1.position(degrees) + Motor20.position(degrees) + Motor11.position(degrees) +
Motor4.position(degrees) + Motor5.position(degrees) + Motor10.position(degrees)) / 6 < target) {
wait(10, msec);
// 20, 11 = left 5, 10 = right
// Stop motors
Motor1.stop();
Motor20.stop();
Motor11.stop();
Motor4.stop();
Motor5.stop();
Motor20.stop();
//Ties the motors to the joysticks
int axis3Position = Controller1.Axis3.position();
//int axis2Position = Controller1.Axis3.position();
if (axis3Position> 0.0) {
else {
Motor20.stop();
wait(20, msec); // Small delay to prevent the CPU from committing suicide
edit: code tags added by mods, please remember to use them.
