Help with dr4b in fusion 360
So I am currently making my dr4b in fusion 360, and I have come across an issue I can’t seem to solve.
The left side of the lift works flawlessly, but as soon as I joint the other side of the lift, it doesn’t allow me to move the lift. I have tried every type of joint with no solution.
Thanks
Have you tried creating the two sides separately and then using the “Motion Link” feature? (this constrains two joints to always move together) I’ve found that that works best for me when creating lifts in Fusion.
Thank you for the quick response! Motion linking 1 joint on each side did cause them to move together. Thank you for the solution
