Looks like that code came from this old post.
omni directional motion
That’s a 3 year old post, not sure what I was exactly working on back then.
Learn about holonomic drives by reading the explanation by Cody.
Holonomic drives 2.0: A video tutorial by Cody
The idea behind the field centric control is to then modify the “forward” and “sideways” control values based on which way a gyroscope tells us the robot is pointing. The “front” of the robot always points away from you, we use simple trig equations to do the modifications.
Here is some UNTESTED (I’m tired tonight) code that has all of the necessary functions, I will check it at the weekend if I have time.
#pragma config(Sensor, in1, gyro, sensorGyro)
#pragma config(Motor, port2, MotorLF, tmotorVex393_MC29, openLoop, encoderPort, None)
#pragma config(Motor, port3, MotorLB, tmotorVex393_MC29, openLoop, encoderPort, None)
#pragma config(Motor, port8, MotorRB, tmotorVex393_MC29, openLoop, reversed, encoderPort, None)
#pragma config(Motor, port9, MotorRF, tmotorVex393_MC29, openLoop, reversed, encoderPort, None)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
/* Field centric control demo code */
/* James Pearman 2015 */
/* Licensed under the Apache License, Version 2.0 (the "License"); */
/* you may not use this file except in compliance with the License. */
/* You may obtain a copy of the License at */
/* http://www.apache.org/licenses/LICENSE-2.0 */
/* Unless required by applicable law or agreed to in writing, software */
/* distributed under the License is distributed on an "AS IS" BASIS, */
/* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. */
/* See the License for the specific language governing permissions and */
/* limitations under the License. */
/* The author can be contacted on the vex forums as jpearman */
/* or electronic mail at jbpearman_at_mac_dot_com */
/* Mentor for team 8888 RoboLancers, Pasadena CA. */
/** @brief Get the gyro angle */
/** @returns gyro angle in 0 - 360 deg range */
float
GyroGetAngle()
return( SensorValue gyro ] / 10.0 );
/** @brief control the mecanum drive */
/** @param[in] forward The forward power/speed (-127 to 127) */
/** @param[in] turn The turning power/speed (-127 to 127) */
/** @param[in] right The strafing power/speed (-127 to 127) */
void
DriveSystemMecanumDrive( int forward, int turn, int right )
long drive_l_front;
long drive_l_back;
long drive_r_front;
long drive_r_back;
// Set drive
drive_l_front = forward + turn + right;
drive_l_back = forward + turn - right;
drive_r_front = forward - turn - right;
drive_r_back = forward - turn + right;
// normalize drive so max is 127 if any drive is over 127
int max = abs(drive_l_front);
if (abs(drive_l_back) > max)
max = abs(drive_l_back);
if (abs(drive_r_back) > max)
max = abs(drive_r_back);
if (abs(drive_r_front) > max)
max = abs(drive_r_front);
if (max>127) {
drive_l_front = 127 * drive_l_front / max;
drive_l_back = 127 * drive_l_back / max;
drive_r_back = 127 * drive_r_back / max;
drive_r_front = 127 * drive_r_front / max;
// Send to motors
// left drive
motor MotorLF ] = drive_l_front;
motor MotorLB ] = drive_l_back;
// right drive
motor MotorRF ] = drive_r_front;
motor MotorRB ] = drive_r_back;
/** @brief Driver control of mecanum drive system */
void
DriveSystemMecanum()
int forward, right, turn;
int temp;
float theta;
// Get joystick values
// deadband near center of joysticks
forward = vexRT Ch3 ];
if( abs( forward ) < 10 )
forward = 0;
right = vexRT Ch4 ];
if( abs( right ) < 10 )
right = 0;
turn = vexRT Ch1 ];
if( abs( turn ) < 10 )
turn = 0;
// Field centric control
// Get gyro angle in radians
theta = degreesToRadians( GyroGetAngle() );
// rotate coordinate system
temp = forward * cos(theta) - right * sin(theta);
right = forward * sin(theta) + right * cos(theta);
forward = temp;
// Send to drive
DriveSystemMecanumDrive( forward, turn, right );
task main()
// Init the gyro
SensorValue gyro ] = sensorNone;
wait1Msec(100);
SensorValue gyro ] = sensorGyro;
wait1Msec(1000);
while(1)
DriveSystemMecanum();
wait1Msec(25);
