Hello everyone,
I am trying to create objects that mirror the goals on the Change Up field. I am using extended data to assist me with this.
First, I create a new struct.
typedef struct {
lv_imgbtn_ext_t tower;
std::vector<char> balls;
bool disabled = false;
} tower_t;
Then, I define an array of nine pointers to tower_t
tower_t * towers[9];
I also create an array of nine lv_obj_t *, which corresponds to the actual objects displayed on the screen.
lv_obj_t * towers_obj[9];
I then create a for-loop to iterate through this array and set/get the extended data.
for(int i = 0; i < std::size(towers); i++){
lv_obj_allocate_ext_attr(towers_obj[i], sizeof(tower_t));
towers[i] = (tower_t*) lv_obj_get_ext_attr(towers_obj[i]);
Finally, I assign a vector to towers[0]->balls
towers[0]->balls = {'r', 'b'};
The problem is, after assigning the vector to towers[0]->balls
, the program freezes. Any idea why?
EDIT: I solved the issue. Just don’t use extended data.
