My team has been struggling with creating a functioning line tracker program. We’ve been researching and programming for two days. If anyone could send a picture of their line tracker program or an example line tracker program, that would be much appreciated.
Could you post what you have right now? I could give advice on how to make it work.
In general you want your line tackers as close as possible to the object/floor.
PseudoCode:
while(LineTracker Value greater than some value){
Motor spin
Motor stop
What this code will do is once the line tracker senses something, it will make the motor stop spinning
Thank you so much. We just figured out the problem. Turns out it was a configuration error
