Hello so let’s get to the point: I am making a mecanum base with my team but we want to use a vex drivetrain inside the autonomous function. However, the drive train is available for all the code so it make our base go a LITTLE BIT HOT (we we’re able to do 7 minute without dying now it’s 3 MINUTES ONLY)
I tried to put Private infront of : smartdrive AutonomusDriveTrain = smartdrive(LeftSide,RightSide, Inertial10);
but it just gave me an error
Here is the code:
int autonomousmode() {
AutonomusDriveTrain.setDriveVelocity(100,percent);
AutonomusDriveTrain.setTurnVelocity(100,percent);
AutonomusDriveTrain.driveFor(forward,200.0,mm,true);
AutonomusDriveTrain.turnToHeading(90, degrees);
// drivetrain AutonomusDriveTrain = drivetrain();
Brain.Screen.print("\033[30m");
return 0;
thank you in advance!
