Help with traybot arm
‘Single gear’ as in you use one gear with a chain grips wrapped around it, having it spin using a motor. someing like this picture below.15751418348624565687638062661817
any pictures of your current design would be helpful to give you more specific help, but also remember that compression is important to pick up cubes
What do you mean a single gear intake? Do you mean a single sprocket? If so, I would recommend you to double sprocket intakes, with chain in between them to grip the cubes and make a pivot point using a screw joint or a hinge to flip it down. Have something hold it in, but have something release it.
Screw joints:
Hinge:
That is a “chintake” and they use double sprockets as well, staggered. You drive it with a motor, and (i was using chain in that photo) use gears to drive the front one, with a ratio.
Thank you. that was really helpful. We appreciate it.
