Help with video
Is there way to play a video on the VEX5 robot brain ?
You can display GIF images on the brain, and using LVGL I’m sure there’s a way to make a video player.
we do not provide that as a standard capability, it can be done, but not trivial.
Was that a 28 second video on the brain?
so that was an 8 second clip from something I found on vimeo.
fireplace -1971
I converted that into an image sequence. placed the frames on an SD Card and then wrote a small program (just a hack, the code is not pretty ) to play the frames. They were read into memory first.
fireplace demo
//  main.cpp
//  Created by <user> on Mon Dec 24 2018.
//  Copyright (C) 2018 <team>. All rights reserved.
#include <stdio.h>
#include "v5.h"
#include "v5_vcs.h"
using namespace vex;
brain Brain;
uint8_t   imageBuffer[ 240 * (128 * 1024) ];
uint32_t  imageBufferLen[240];
void
fireplaceInit() {
  char  filename[32];
  Brain.Screen.clearScreen();
  for(int file=0;file<240;file++) {
    int offset = file * (128 * 1024);
    sprintf(filename,"images/fire_%05d.png", file );
    imageBufferLen[file] = Brain.SDcard.loadfile( filename, &imageBuffer[offset], 128 * 1024 );
    Brain.Screen.printAt( 10, 20, "Loading.. %3d", file );
void
fireplace() {
  int   file = 0;
  char  banner[] = "Happy Holidays 2018";
  int   pos1 = 480;
  int   pos2 = 960;
  fireplaceInit();
  Brain.Screen.setFont( fontType::prop40 );
  Brain.Screen.setPenColor( color::red );
  while(1) {
    Brain.Screen.drawImageFromBuffer(&imageBuffer[offset], 0, 0, imageBufferLen[file]);
    Brain.Screen.printAt( pos1, 40, false, banner);
    Brain.Screen.setPenColor( color::green );
    Brain.Screen.printAt( pos2, 40, false, banner);
    Brain.Screen.render();
    file ++;
    if(file == 239 )
      file = 3;
    pos1-=4;
    if( pos1 < -480 )
      pos1 = 480;
    pos2-=4;
    if( pos2 < -480 )
      pos2 = 480;
int main() {
  int count = 0;
  fireplace();
  while(1) {
    Brain.Screen.printAt( 10, 50, "Hello %d", count++ );
    // Allow other tasks to run
    this_thread::sleep_for(10);
