Hi, we need help with digital output for pneumatics
hi, the problem we have is related with the pneumatics logic, we couldn´t get a correct sintaxis on the vex code v5, and can´t call the 3 wire port of the piston on the code like digital output, any help on any way is welcome!
english isn´t my mother tongue, thanks
Welcome to the forum!
For us to help you, we need a little more information.
Can you send the code you have right now?
the problem is on the robot-config file, we need to find the sintaxis to call the digital output
do you have code of pneumatics?, it will be useful
thanks for the hospitality <3
If you are configuring things through the graphical devices menu, there is an option “digitalout” under “3-wire”.
If you have “Expert Robot Configuration” turned on, and are editing robot-config.h manually, the syntax to initialize a digital out is:
digital_out myDigitalOut(Brain.ThreeWirePort.A);
(replace A with whatever port you’re’ actually using)
here is my robot-config file, underlined in red is the pneumatic configuration.
“Pneumatic” is just the name of the digital out we chose
and using it in code is simple: image
these are just functions to push and pull back the pneumatic
do you use controls configurations on pneumatics?
thanks <3<3<3<3<3<3<3
thanks<3<3<33<3<3<3<3<3<3
Side note: your English is great. Let me catch a detail: “sintaxis” becomes “syntax” in English. If you ever do experience difficulties in translation during a conversation, you can include how you would say it in your first language, and we can explore translation in google or similar. I had a productive conversation with a user whose first language is Spanish this way a few months ago.
Nota al margen: tu inglés es genial. Permítanme darles un detalle: “syntax” se convierte en “syntax” en inglés. Si alguna vez experimenta dificultades de traducción durante una conversación, puede incluir cómo lo diría en su primer idioma y podemos explorar la traducción en Google o similar. Tuve una conversación productiva con un usuario cuyo primer idioma es el español de esta manera hace unos meses.
https://translate.google.com/
Presiono las flechas de intercambio varias veces hasta que las traducciones dejan de cambiar. De esa manera puedo estar bastante seguro de que funcionó bien.
