So it started today where my high hang won’t line up properly with the other beam. When my high hang goes up one side is tilted. I tryed lining up the gears, it did not work. I tryed lining up the beams then putting it in the gears still did not work. The world is in few days and I need help now.
You should know the drill by now. We need pictures or we can’t really help.
Well now I spent 4 hours and the solution is to swap the shaft, I am really sorry. For the people out there if your high hang is not lined up properly and you line the gears and swaped the gears as well. Then replace the shaft.
