Our robot is able to high hang without touching the field perimeter at all. However, our robot is tilted in a way that the outermost wheel is slightly below the perimeter. Can we still get the points for high hanging even though our robot is partially below the field wall?
The only way you can tell is if you took a yardstick and slide it across the perimeter below the robot.
I’d also like to make it clear that our robot is NOT touching the field wall in any way, we are only touching the hanging bar when we lift.
