Hey I would like to know if the 2-wire vex 393 integrated encoder modules work on a 2-wire vex high speed motor
They will work no matter what gears you put inside the motor, as long as you have the special encoder gear in there.
thanks
Just a friendly reminder, you don’t need to spam the forums for an answer just be patient.
thanks
so it would work on a turbo motor too?
Yes any gears will work if you have the IME set up correctly
thanks
