Hello, I just finished building and I realized the chain was too long (73 chain). When I tried to take two of them out, the chain wasn’t long enough to connect. Does anyone know the solution?
Have you tried removing just one?
If that doesn’t work then go ahead and look into building a tensioner.
Just remove 1 then. And it’s OK to leave the chain loose (Not too loose though.)
I tried removing one chain it still doesn’t connect. Almost touching.
If it doesn’t work with 73 because it is functionally to much slack you could try a tensioner, Just a screw or spacer in the normal path of the chain so it has to go around it should work
You gotta position it right and pull hard on it and connect it
Can you send a photo of the arm?
