I’m only seeing the portable perimeter instructions. Is this coming with the hardware for the original perimeter?
The field only comes with hardware for the portable perimeter, but it’s pretty easy to adapt to the metal perimeter - off the top of my head, all you need is a few shorter screws for the wall-mounted stakes.
No, unlike the last few game elements these will not come with hardware for both fields, however the insurrections should note where you have to use alternate hardware for the metal field perimeter. For the most part it will be a .5 in screw instead of a 2.5 in screw for the metal v. portable field.
There is one page that shows the different size screw for metal perimeters to attach wall stakes. Other than that, all the same.
The stickers and side panels are different though. The sticker we got were too thick and the markers for corners we had to custom fit.
the Side + - signs are easy to mount to metal field perimeter, just use a small piece of tape. The top ± are wider, I have seen then folded over the top of field perimeter and seems to work ok.
no impact to game play.
Yeah exactly what we did but it is very annoying and IK that at least one team at our comp will complain about it
In-head reply “Delighted to have you volunteer at our events for setup… even better if you host events as well!”
Official Game Manual response “<T11> Fields may be repaired at the Event Partner’s discretion”
