I would like to develop applications for the VEX Cortex but I only see support for V5. How Can I Compile Applications For VEX Cortex Using PROS? Can it be done?
@OscarMNOVA12 Gave docs to the PROS 2 API, but I’m not sure if the instructions for actually creating a PROS 2 project using the PROS 3 CLI is in there. In any case, assuming you have the PROS 3 CLI installed, you can create a new project as usual using the CLI, except with the addition of an extra argument “cortex” at the end, e.g. pros conduct new-project /path/to/project/folder cortex
Thank you! I will check them out and give it a try.
Thank you for your help. I will check it out soon.
Thank you again, it worked!!!
