How can I simplify this code?
task usercontrol()
	while(1 == 1)
		//Claw Control
		if(vexRT[Btn6U] == 1)
			motor[clawMotor] = 127;
		else if(vexRT[Btn6D] == 1)
			motor[clawMotor] = -127;
		else
			motor[clawMotor] = 0;
		//Arm Control
		if(vexRT[Btn5U] == 1)
			motor[armMotor] = 127;
		else if(vexRT[Btn5D] == 1)
			motor[armMotor] = -127;
		else
			motor[armMotor] = 0;
		// Score Control left
		if(vexRT[Btn7U] == 1)
			motor[leftscoreMotor] = 127;
		else if(vexRT[Btn7D] == 1)
			motor[leftscoreMotor] = -127;
		else
			motor[leftscoreMotor] = 0;
		//score Control right
			motor[rightscoreMotor] = 127;
			motor[rightscoreMotor] = -127;
		else
			motor[rightscoreMotor] = 0;
			//Drive left and right
			motor[leftMotor] = vexRT[Ch2];
			motor[rightMotor] = vexRT[Ch3];
This is pretty much as simple as it gets for basic code for a robot. One thing you could do it combine the score right and score left if/else statements
Ex:
		else
if you want to get really nit-picky, you could get rid of the brackets around
because they don’t really go anything.
Also you can just say while(true) instead of while (1 == 1)
Assuming you mean braces and not brackets, it is good practice to keep them, as most languages (except for Python and a couple others) require them, and they help to keep the code organized.
EDIT Thought you were talking about the lift code, nvm
Okay thanks,
Correct me if I’m wrong… but I believe you could simplify like below:
task usercontrol()
	while(1)
		//Claw Control
		if(vexRT[Btn6U])
		else if(vexRT[Btn6D])
		else
		//Arm Control
		if(vexRT[Btn5U])
		else if(vexRT[Btn5D])
		else
		// Score Control
		if(vexRT[Btn7U])
			motor[rightscoreMotor] = motor[leftscoreMotor] = 127;
		else if(vexRT[Btn7D])
			motor[rightscoreMotor] = motor[leftscoreMotor] = -127;
		else
			motor[rightscoreMotor] = motor[leftscoreMotor] = 0;
My preference would be to create a reusable function like this:
// Reusable function that takes two buttons as inputs and returns the new speed
int SetMySpeed(bool bUpPressed,bool bDownPressed)   // returns speed
	if(bUpPressed)  // up button is being pressed
		return 127;
	if(bDownPressed) // down button is being pressed
		return -127;
	return 0;   // nothing bring pressed speed is zero
Then use the new function in usercontrol like this:
task usercontrol()
	while(1)
		// set speed for claw
		motor[clawMotor] = SetMySpeed(vexRT[Btn6U], vexRT[Btn6D]);
		// set speed for Arm
		motor[armMotor] = SetMySpeed(vexRT[Btn5U], vexRT[Btn5D]);
		//set score control
		motor[leftscoreMotor] = SetMySpeed(vexRT[Btn7U], vexRT[Btn7D]);
		motor[rightscoreMotor] = SetMySpeed(vexRT[Btn7U], vexRT[Btn7D]);
		// don't forget this wait at the bottom of the loop
		wait1Msec(20);
Actually, if all you do is an arm control, use the armControl function (enable Natural Language in Robot->Platform Type)
task usercontrol()
	while(1 == 1)
		//Claw Control
                armControl(clawMotor, Btn6U, Btn6D, 127);
		//Arm Control
                armControl(armMotor, Btn5U, Btn5D, 127);
		// Score Control, both left and right
                armControl(leftscoreMotor, Btn7U, Btn7D, 127);
                armControl(rightscoreMotor, Btn7U, Btn7D, 127);
		//Drive left and right, as long as you have proper drivebase config in motor setup
                tankControl(Ch2, Ch3);
BTW: “Natural Language” is pretty much just a library of functions, you can inspect them using right click->Go to Definition/Declaration. You can always write functions like this better taylored for your uses.
You could get it down to 1 line of code using ternaries, but I think what was posted above is simpler (As in less complicated)
If you want really super simple code, you could do something like:
motor[clawMotor] = VexRt[Btn6U]*127 - VexRt[Btn6D]*127;
motor[armMotor] = VexRt[Btn5U]*127 - VexRt[Btn5D]*127;
motor[rightscoreMotor] = motor[leftscoreMotor] = VexRt[Btn7U]*127 - VexRt[Btn7D]*127
