How do I generate a number between 1-180 in vex exp
Depends on what language you are coding in.
Blocks is the easiest:
Python:
urandom.randint(1, 180)
C++ is more complicated:
#include <time.h> //for time
int main() {
srand(time(NULL)); //set random seed
Brain.Screen.print((rand() % 180)+1); //get random from 0 + 179 and then add 1 to result
I’m not sure how well this would work though because I don’t know how system time works on EXP, @jpearman might know a better way of doing this.
Side Note
When I tried this code using Mersenne twister:
Code
//include random library
#include <random>
int main() {
//setup random number generator
std::random_device dev;
std::mt19937 rng(dev());
std::uniform_int_distribution<std::mt19937::result_type> dist180(1,180);
//call random number
Brain.Screen.print(dist180(rng));
I get this error:
Error
unix build for platform vexexp
CXX src/main.cpp
In file included from src/main.cpp:49:
In file included from /home/ubuntu/cloudcompiler/Tools/sdk/vexexp/20240219_10_00_00/gcc/include/c++/7.3.1/random:38:
/home/ubuntu/cloudcompiler/Tools/sdk/vexexp/20240219_10_00_00/gcc/include/c++/7.3.1/cmath:45:15: fatal error: ‘math.h’ file not found
#include_next <math.h>
1 error generated.
make: *** [vex/mkrules.mk:13: build/src/main.o] Error 1
make process closed with exit code : 2
Does anyone know why this is happening?
You must be using the cloud compiler, it still seems to on on an old version of the build system. That’s caused by an issue with toolchain include path order.
Yeah, I’m on cloud compiler. Would that not be an issue on other platforms?
The desktop apps were updated, as was VSCode. I thought the cloud compile system had been, but apparently not. It’s an issue with #include_next
in the system headers. It’s probably an issue for IQ2 as well, but using C++ standard library on IQ2 is often not viable due to lack of memory. I don’t think this was ever an issue for V5 (older version of system headers).
