I’m always having trouble with my robot having its motion stunted. For example, when I quickly switch directions forward and backward, the entire robot is lifted off the front or back two wheels. I am already fixing the balance of the robot to try and prevent this, but are there any code changes to make the motors for the wheels to coast? Do I set this in the motor initialization part or in the main user control task?
Here’s my motor initialization:
competition Competition;
controller Controller1;
motor leftFront = motor (PORT1);
motor leftBack = motor (PORT2);
motor rightFront = motor (PORT3, true);
motor rightBack = motor (PORT4, true);
And here is the my user control:
void usercontrol(void) {
while (1) {
leftFront.setBrake(brakeType::coast);
leftBack.setBrake(brakeType::coast);
rightFront.setBrake(brakeType::coast);
rightBack.setBrake(brakeType::coast);
leftFront.spin(directionType::fwd, Controller1.Axis3.position(), pct);
leftBack.spin(directionType::fwd, Controller1.Axis3.position(), pct);
rightFront.spin(directionType::fwd, Controller1.Axis2.position(), pct);
rightBack.spin(directionType::fwd, Controller1.Axis2.position(), pct);
Will this code work, or do I need to add something else?
I think this is a problem of mechanical structure rather than program.Do you have a high center of gravity?You should try to lower the center of gravity.
The brake type you set only valid for Motor.stop().It won’t work when Motor.spin() called.
This doesn’t sound like a programming problem, and instead sounds more like a weight distribution problem and a driving problem. If quickly going from full forward to full reverse tips your robot, then you can try getting better at not doing that when you drive, and instead try to move the stick more smoothly.
You have to remember that coast, hold and brake modes for the motor only apply when the motor is actually stopped. If you send a motor command to spin the motors in the opposite direction while is is moving, the expected result with a light and possibly unbalanced robot is as you are observing.
The function is supposed to run before autonomous code, and the reason it might be better to move it there is because you really only need to call the brakeType once
setBrake is an old deprecated API, we changed the name to setStopping a couple of years ago to better reflect it’s functionality. They do the same thing.
