I need help with programing an drive for my team and I don’t know where to start. If some one could help me I would really appreciate the help.
The same way you program an X drive on robotc, only this time you are setting the velocity with a function instead of a variable.
Hi Error101,
I would check out this video. Start at about 0:40 for the programming part. This video really helped me to understand an X drive. Although it is in ROBOTC with the cortex system, it should translate over to vexcode pretty well
Do you have an example of any vexcode x drive code I’m not the best at vexcode as this is my first year
It’s al right if you don’t though
Basically, you would just want to say
while(true){
/keeps this code always repeating
LeftFront.spin(forward);
/keeps the motor always "on"
LeftFront.setVelocity(Controller1.Axis2.position()+Controller1.Axis1.position()+Controller1.Axis4.position(), percent);
//Sets the motor speed
//Do this for all motors with the equations shown in the video
Thank you so much all
You could replace the
with
LeftFront.spin(forward,Controller1.Axis2.position()+Controller1.Axis1.position()+Controller1.Axis4.position(), percent);
To make it less confusing.
