I was re-reading this post and I finally want to know the answer - how do you color code code in the esoTalk forums?
Are there bb code values you give?
Reference post with color coded code:
https://vexforum.com/t/flywheel-velocity-control/29892/1
Hi Team80_Giraffes,
To use Syntax Highlighting in your posts, simply wrap your code in the "
" tags, which can be found in the menu bar of a new post. Javascript will then detect and highlight the code automatically.
Note: If you preview the post, the highlighting will not show.
