How do you name a line tracker? (in VEX code V5 text)
Hello, how do you name a line tracker?
// THREE WIRE DEFINITION
line SensorName (Brain.ThreeWirePort.A);
//other 3wire sensors: https://api.vexcode.cloud/v5/html/classvex_1_1____tridevice.html
I’m quite confused on what you mean. Are you talking about in programming? Then, if so, what programming langauge are you using? If you’re talking about in general, does “Bill” sound like a good name for a line tracker?
Edit//: Just realized it was in the title. Click the little button on the top right of the menu that looks like a female RJ11 connector, click “3-Wire,” and click “LINETRACKER”. Select the port and you should see a text box appear where you can give it a name.
