How many degrees does the Vex servo turn?
The product page says 100 deg, but I read this in a document I found through Google:
So which is it?
P.S. This question is with respect to using EasyC.
This thread has your answer https://vexforum.com/t/answered-servo-rotation-100-or-180-degrees/15917/1 about how far it goes (and that it seems to go farther when you turn it by hand).
General experience has been that it’s just a few degrees less than what I want to use it for. :frowning:
The Servo can be turned until the Mechanical Stops…
The default Pulse Width Modulation is less than the Stops. If you code your own PWM ( PPM4VEX Library for driving more motors/servos ), then you can drive it further than the default Code…
