According to rule <R12>, robots may use up to 12 motors on the V4 Cortex. However, rule <R13> states a robot can only use 1 Y-cable. These rules are contradictory, since 12 Motors require two Y-Cables.
My question is which setup can teams use:
I’m under the impression that you can have as many as you want so long there is only one per port and you stay within the motor maximum, which is 12 for the legacy system. Theoretically, you’d never need more than 4 because there’s 8 motor controller-accessible ports and 4 y-cables would let you have 12 motors
