Foster
December 10, 2023, 5:46pm
1
This was last asked in 2008 by @Quazar , and I’m interested to see how things have changed. (His max was 17)
I’m looking for responses in a format like
Total 12 - V5 Brain
6 Motors
Vision Sensor
2 Bumper Switches
2 Potentiometer
Line Sensor
This is in the V5 forum, but if you are an IQ user put your port counts in, please mark that you have an IQ brain, thanks.
Last year I had 8 motors, 2 distance sensors, 1 rotation sensor1 radio, and 6 solenoids.
bantha
December 10, 2023, 10:06pm
4
V5 Brain
- 7 motors
- Inertial Sensor
- 2 solenoids
Last Robot
V5 Brain
17 Total
9 Motors
3 Rotation sensors
Inertial sensor
Radio
2 Solenoids
LED license plate
74403b
December 13, 2023, 1:45am
7
10 motors
3 limit switch
inertial
vision
line tracker
3 wire expander
Mavric
December 13, 2023, 1:59pm
8
Current Robot
V5 Brain
13 Total.
Smart Port
8 Motors
Inertial sensor
Radio
3 Wire
Going to add a 3 wire bumper soon for my new cata.
Slapshot IQ Post
Would Have been my worlds robot but I did not make it
12 Total - IQ 2nd Gen Brain
6 Motors
2 Vision Sensors (Calculate disk distance relative to the robot for changing the power of the flywheel)
1 Distance Sensors (Front Distance to import the distance into the kinematics equation)
3 Color Sensor (Used to read the lines on the field to keep and track position)
-Blaziumm
CU
worlds bot 7th grade
4 motors
1 radio
1 controller
TiP
worlds bot for our final year in MS
7 motors
1 inertial sensor
1 radio
1 controller
SU
freshman year states bot
8 motors
1 inertial sensor
1 color sensor
1 radio
2 potentiometers
1 solenoid
1 controller
Over Under
soph year 1st tournament
7 motors
1 radio
1 inertial sensor
1 limit switch
3 solenoids
1 radio
1 controller
inertial sensors were used once we realized that it would help in autonomous and we also learned how to use limit switches
First Tipping Point Bot (total 8 smart ports):
Second Tipping Point Bot (total 10 smart ports and 2 three wire ports):
8 Motors
1 solenoid
1 IMU
1 Limit Switch
1 Radio
Last Tipping Point Bot (total 12 smart ports, 5 three wire ports):
8 motors
1 Rotation sensor
1 IMU
1 Radio
3 wire expander
1 limit switch
1 bumper sensor
3 solenoids
First Spin Up Bot (total 16 smart ports, 2 three wire ports):
8 motors
2 solenoids
2 optical sensors
4 rotation sensors
1 IMU
1 Radio
Last Spin Up Bot (total 15 smart ports, 6 three wire ports):
8 motors
6 solenoids
2 optical sensors
1 IMU
3 Rotation sensors
1 Radio
First Over Under Robot (total 14-15 smart ports, 5 three wire ports):
8 motors
1 three wire expander
1 IMU
3 Rotation sensors
1 Radio
1 GPS (only at our first comp, we removed it by the second one)
Second Over Under Robot (not completed yet, so this is a guess; total 13 smart ports, 6 three wire ports):
8 motors
2 Rotation Sensors
6 solenoids
1 IMU
1 Distance sensor
1 Radio
how did you get away with 4 motors for your cu bot
We use 11 total.
8 motors,
2 rotation sensors,
and an inertial sensor
You should always use all 8 motors that you’re allowed to use. If you use 6, use the last two motors on the drivetrain for more power
system
Closed
January 8, 2025, 8:16pm
15
