Im curious how much of the 100 psi teams are saving for their endgame. Or how much psi teams are using on their pneumatics if they have motor powered elevation.
How much psi are you using per match before climbing?
Definitely, 25+. Depending on your endgame and how the rest of your pneumatic system works I might even suggest having a separate tank for endgame climbing to make sure you have the full 100 psi if needed. I mean in a ha
E where you might be using your wings a lot of might have a lifted shooter your air usage will vary from a little to a lot and a separate tank for endgame might be the best option the air cylinders can output max force at the end if needed.
