I am trying to to come up with a way to mount a rubber link parallel to a 5 wide c-channel. In other words trying to find a way to mount it as if it were laying on a piece of 5-wide pointing down the channel long ways. I thought about wheels collars, but screw sizes are wrong and the thickness might be too thick. Has anyone come up with similar situation or solution?
Shaft collars can work. On a 5 wide c channel a pillow block could work too.
Can you try and draw a picture and upload with your camera?
Have you tried unscrewing a set screw from a shaft collar and screwing in the rubber piece there and then screwing the shaft collar to the c-channel?
Maybe try a standoff or a segment of standoff(s) with shaft collar and screw?
https://vexforum.com/index.php/attachment/56464da53cba9_IMG_9339.jpg
https://vexforum.com/index.php/attachment/56464da53cfc6_IMG_9338.jpg
Images are from jpearman
Thanks guys!
