How to add objects to a vector?
In my experimental code, I’m trying to add some objects to a vector (the approx. equivalent of arrayList in java) so I can access these objects fairly easily and have them organized in one location. The only problem is I can’t figure out how to add the objects to the vector. Any help would be appreciated.
ObjsToVector
you probaly shouldn’t be using vectors if you’re this new to c++. That being said, define red2 on a seperate line, and then pass red2 to the function.
I mean I’ve done object oriented before, just in Java. The problem is even if I use the already created red1, it still doesn’t work.
Edit:
initBoi(red1); doesn’t work either.
try using pass by reference. basically, slap an ampersand into the function declaration before obj
hold on, i’m actually stupid. i forgot to put it into a task.
