How To Code More Than 1 Motor to 1 Button
I’ve been trying to code my intake motors 2 buttons R1 and R2 on the V5 controller, but I can’t because Vex Code v5 only lets you do 1 motor per button in the controller configuration menu. Is there a way around this?
If the config menu doesn’t give you the option, you’re going to have to write your own code. Are you using regular vexcode or vexcode pro?
I’m using normal vexcode. How would I go about doing it on my own?
In the latest release of VEXcode, you can create a motor group of two motors and then assign that to buttons in the controller setup.
Nice! I’ll try that and see if it fixes the problem
https://kb.vex.com/hc/en-us/articles/360058592211-Configuring-a-Motor-Group-in-VEXcode-V5
