How to count in this situation?
a green cube is both on the green base cube and a red cube.If referee remove the red one,the green that on the top would fall down.How to count in this situation?thank you
Each Cube in the Highrise must be fully supported by the Highrise or the Highrise Base Cube. Since the red Cube is not part of the Highrise and appears to be supporting the Highrise, it would be pulled away by a referee. If the top Green Cube remains in place once the Red Cube is pulled away, the Highrise Height would be 2. If it falls off the Highrise Base Cube, the Highrise Height would be 1.
Thank you!
You’re welcome!
