How to Display Image on V5 Brain?
does anyone know how to display an image on a vex brain? thx :slight_smile:
Search bar is your friend.
I’ve tried those, in vex code v5 pro it doesn’t recognise that command :frowning:
There are definitely replies in some of those threads that show how to display images on the brain in VEXcode pro V5.
The relevant function call is brain::lcd::drawImageFromFile.
If you’re having trouble using that function, post your code and someone can take a look at it.
ok thx
its not working :frowning:
Brain.Screen.drawImageFromFile
thank you :slight_smile: however now its giving me this error image
do i need to specify image length and width?
look at the API that was linked above, you need to specify position.
The image needs to be either a .bmp or .png image, a jpeg image will not work.
The image needs to be no larger than the V5 screen, it will not be resized.
ok, thank you :slight_smile:
I also have the same question. Thanks for solutions.
Read the documentation James posted above.
