How To Escape Standalone Mode
This is a follow-up question to Question 3 in my previous post. How do I escape from Standalone Mode once I have downloaded a program to the Cortex via USB? Once I download a program to the Cortex via USB, I am unable to regain control of the Cortex without using the Reconfig button and going through the pairing procedures with the joystick all over again. I have some robots in my class that are stuck in Standalone Mode.
Thanks!
See my previous answer.
You have to download the RobotC program in either of the two communications modes I mentioned, that’s the only way, the cortex will then start looking for a VEXnet key and try and connect to a joystick. The actual connection (whether you use the USB A-A cable or programming kit does not matter, you can select one of those two modes and still use the USB cable directly to the cortex)
