How to get coast breaking mode for flywheel in blocks code
i’m trying to reduce overheating of my motors for the flywheel by i’m not sure how i should go by doing it in blocks code could you help?
Overheating of motors is not so much as code, but more as the robot’s actual build and piloting. You shouldn’t be consistently spinning the flywheel at high speeds for longer periods of time. Your robot should also have a efficient way of slowing down and stopping the flywheel once your done using it for your shooting.
(Oh and I forgot to add this bit at first, but I’m sure that threads have discussed topics such as this, and all it takes is a quick search to find this)
If you want to coast use the “set motor stopping” block and set it to coast. Then, use the stop motor block.
