What i mean by how to gyroscope, is that I’m wondering how to code a gyroscope, and where to place/build it onto a robot.
Right now I have this code:
void gyro(int angle) {
angle = angle*10;
//Specify the amount of acceptable error in the turn
int error = 5;
//While the absolute value of the gyro is less than the desired rotation - 100...
while(abs(SensorValue[in3]) < angle - 100)
motor[FR] = 50;
motor[FL] = -50;
motor[BR] = 50;
motor[BL] = -50;
//Brief brake to eliminate some drift
motor[FR] = -5;
motor[FL] = 5;
motor[BR] = -5;
motor[BL] = 5;
wait1Msec(100);
//Second while loop to move the robot more slowly to its goal, also setting up a range
//for the amount of acceptable error in the system
while(abs(SensorValue[in3]) > angle + error || abs(SensorValue[in3]) < angle - error)
if(abs(SensorValue[in3]) > angle)
motor[FR] = -30;
motor[FL] = 30;
motor[BR] = -30;
motor[BL] = 30;
else
motor[FR] = 30;
motor[FL] = -30;
motor[BR] = 30;
motor[BL] = -30;
//Stop
motor[FR] = 0;
motor[FL] = 0;
motor[BR] = 0;
motor[BL] = 0;
wait1Msec(250);
task autonomous()
//Completely clear out any previous sensor readings by setting the port to "sensorNone"
SensorType[in3] = sensorNone;
wait1Msec(1000);
//Reconfigure Analog Port 3 as a Gyro sensor and allow time for ROBOTC to calibrate it
SensorType[in3] = sensorGyro;
wait1Msec(2000);
So let’s say i want the robot to go back, throw and star over, then go for the middle cube would this work?
task autonomous()
wait1Msec(1000);
wait1Msec(2000);
straight(-127); //robot drives backwards until it gets to wall
wait1Msec(1600);
straight(0);
arm(127); // robot stops at fence and brings arm up to throw preload over
waitUntil(SensorValue[P1] >= armFull);
gyro(45); // <---- here is my main issue, assuming my gyro code above works, would calling the gyro function here rotate the robot 45 degrees exactly? and what if after calling gyro(45); i call gyro(90); would calling gyro(90); rotate the robot 90 degrees from where it is or from the starting point meaning it would be 90 degrees from where it started not 135 degree
I couldn’t find any good tutorials online, this is just what i gathered from the sample programs so I’m looking for someone to help! thank you!
