How to identify motor gear ratio?
How would one identify what gear ratio a certain motor has? I want all my motors to have the same speed.
For a 393 motor? If you didn’t mark it when you changed the internal gears, the only way is to take the front casing off and take a look. Or run them all and you should be able to tell by comparing the speed of the out shaft.
