How to make 4 motors move at once
How do you make four motors move at once
Not even that. Just do this.
You can add a motor group I think… But I am in IQ and im not sure what the coding language is in V5
It pretty luch the same in iqblocks and vrc bl9cks
Ok, I wasn’t sure, if you go to add a device or sensor it will say motor group so just use that
We use Vex Code V5 Pro
C++/ python for most people.
If it’s not a drivetrain then you can add “true” to the end of the argument and that should tell the motors not to wait.
yourmotor.spin(distance, degrees);
yourmotor1.spin(distance, degrees, TRUE);
yourmotor2.spin(distance, degrees, TRUE);
yourmotor3.spin(distance, degrees, TRUE);
Sorry if the syntax isn’t right
I used this
if (Controller1.Axis2.position(pct) != 0){;
Motor1.spin(forward,Controller1.Axis2.position(pct), pct);
Motor2.spin(forward,Controller1.Axis2.position(pct), pct);
Motor3.spin(forward,Controller1.Axis2.position(pct), pct);
Motor4.spin(forward,Controller1.Axis2.position(pct), pct);
