How To Mate Pillow Bearing To C-Channel
I cannot get my pillow bearing block to mate with any metal. How do you guys attach the bearing?
Pictures would be helpful. Thanks!
I assume you are using Jordan’s CAD library. Open up the part and create the iMates yourself.
Okay :slight_smile: I was just confused at first why I didn’t see any.
Um…? What did I say wrong? (:))
The reason that there are none is because the pillow block already has round holes, so mating using Insert constraints is easy. However, I had still planned on adding iMates to parts that already had round holes, just to make it even simpler to see how to connect things.
~Jordan
Nothing, I was being juvenile (and I deleted the post)
Edit: Perhaps that explanation doesn’t belong on vexforum. I forgot that vex in is in elementary school now too.
Jesse, I’ll pm you (although you probably got the email anyway)
Okay, but for some reason, I could not mate the rounded holes to the metal. I will try again later.
Yea, I get it now :smiley: I edited my first post.
