How to print out VexCode V5 block code on paper?
Our VexCode V5 Block programs are getting fairly large. I would like my students to print out their programs on paper for troubleshooting their logic. I can’t find any way to print out the program on paper.
Can someone please point me in the right direction?
Thanks!
Use the Share button - it will generate a PDF broken down into block functions with overview page.
Hope that helps.
Looks like that should work! Thank you!
If you have a solution that works, please press the :ballot_box_with_check: button (approximately) to mark it as solved. This tells people how to do what you wanted to and to not try to solve it.
