The RobotC Blog has an example of one way to write LCD code to do both of those things. I don’t like the way they did their menu system because it leaves redundant code all over the program and won’t let you choose a program to run during intialization, but it will almost work. Their battery code is almost exactly the way I would write it, though. If you’re using a Power Expander, it might be worth looking into the High Resolution Analog Input that will allow you to get that battery’s charge level, too.
http://www.robotc.net/blog/2012/05/18/advanced-applications-with-the-vex-lcd/
I’ve got a version of RobotC running on a different computer now, and I’ll port the code I wrote last night over minus the battery levels if I can ever figure out their LCD Menu commands. I don’t want to do the math for that right now, but the other thing is really easy. Give me 10 minutes, and I’ll see what I can do.
EDIT: Okay, I don’t use RobotC. Ever. But I think that this code should work. If there are errors, it’s in how I tracked button presses from the LCD Screen and/or initialized it. Sorry. I’ve written exactly zero lines of code in RobotC before, and this was the best I could do from their (quite honestly unhelpful) documentation and help page. If someone else could take a look, that would be great.
[Code]#pragma platform(VEX)
//Competition Control and Duration Settings
#pragma autonomousDuration(20)
#pragma userControlDuration(120)
#pragma config(UART_Usage, UART1, uartVEXLCD, baudRate19200, IOPins, None, None)
//Variable that will carry between modes
int Program;
#include “Vex_Competition_Includes.c” //Main competition background code…do not modify!
// Pre-Autonomous Functions
// You may want to perform some actions before the competition starts. Do them in the
// following function.
void pre_auton()
// Set bStopTasksBetweenModes to false if you want to keep user created tasks running between
// Autonomous and Tele-Op modes. You will need to manage all user created tasks if set to false.
//Leave this value alone
int lcdScreenMin = 1;
//This keeps track of which program you want to run
int lcdScreen = 1;
//Change this value to be the maximum number of programs you want on the robot
int lcdScreenMax = 4;
//Turns on the Backlight
bLCDBacklight = true;
//Copied from someone's sample code because the documentation for RobotC won't tell me anything useful
//These should logically work, but I'm not 100% sure
const short leftButton = 1;
const short centerButton = 2;
const short rightButton = 4;
while (vrDisabled == 1) { //Ensures this code will run ONLY when the robot is disabled
if (nLCDButtons == leftButton) { //Scrolls to the left
if (lcdScreenMin == lcdScreen) {
lcdScreen = lcdScreenMax;
wait1Msec(250);
} else {
lcdScreen --;
wait1Msec(250);
if (nLCDButtons == rightButton) { //Scrolls to the right
if (lcdScreenMax == lcdScreen) {
lcdScreen = lcdScreenMin;
wait1Msec(250);
} else {
lcdScreen++;
wait1Msec(250);
if (lcdScreen == 1 && Program != 1) {
displayLCDCenteredString (0, "Program"); //Name the first program here
displayLCDCenteredString (1, "1"); //Name the first program here
if (nLCDButtons == centerButton) {
Program = lcdScreen; //Sets the Program to the one on-screen
displayLCDCenteredString (0, "Autonomous Has");
displayLCDCenteredString (1, "Been Selected!");
wait1Msec(1500);
} else if (lcdScreen == 1 && Program == 1) {
displayLCDCenteredString (0, "Program"); //We use brackets to mark which program we have chosen
displayLCDCenteredString (1, "[1]"); //So that while we're scrolling, we can have one marked
} else if (lcdScreen == 2 && Program != 2) {
displayLCDCenteredString (0, "Program"); //Name the second program here
displayLCDCenteredString (1, "2"); //Name the second program here
wait1Msec(1500);
} else if (lcdScreen == 2 && Program == 2) {
displayLCDCenteredString (1, "[2]"); //So that while we're scrolling, we can have one marked
} else if (lcdScreen == 3 && Program != 3) {
displayLCDCenteredString (0, "Program"); //Name the third program here
displayLCDCenteredString (1, "3"); //Name the third program here
wait1Msec(1500);
} else if (lcdScreen == 3 && Program == 3) {
displayLCDCenteredString (1, "[3]"); //So that while we're scrolling, we can have one marked
} else if (lcdScreen == 4 && Program != 4) {
displayLCDCenteredString (0, "Program"); //Name the fourth program here
displayLCDCenteredString (1, "4"); //Name the fourth program here
wait1Msec(1500);
} else if (lcdScreen == 4 && Program == 4) {
displayLCDCenteredString (1, "[4]"); //So that while we're scrolling, we can have one marked
// Autonomous Task
// This task is used to control your robot during the autonomous phase of a VEX Competition.
// You must modify the code to add your own robot specific commands here.
task autonomous()
if(Program == 1){
//Put your second program in here
else if(Program == 2){
else if(Program == 3){
//Put your third program in here
else if(Program == 4){
//Pur your fourth program in here
// Insert user code here.
AutonomousCodePlaceholderForTesting(); // Remove this function call once you have "real" code.
// User Control Task
// This task is used to control your robot during the user control phase of a VEX Competition.
task usercontrol()
while (true)
// This is the main execution loop for the user control program. Each time through the loop
// your program should update motor + servo values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to update your motors, etc.
UserControlCodePlaceholderForTesting(); // Remove this function call once you have "real" code.
