How to program robot without field
Hi our team has a comp in a week and are wondering how to code a robot without a field. Could we possibly use Desmos if so how
If you mean program an autonomous, you can just measure out the distances for the field elements and go based on that. It should be noted that it would get a lot more difficult if you don’t have the goals for the game.
If you mean program a drive code, you don’t need a field for that, since you can just test your drive code on any surface.
If you can get to the comp early so the practice field is empty and do your auton then if you prefer.
