How to program Vex?
How do you program Vex?:confused: :confused: :confused: :confused: :confused:
first do you have easy c for vex second is there something specific you want to program youre robot to do and if you do have easy c have you tried looking that the programming guide that comes with it , it tells you the basics of programming and has some sample programs to help you hope this helps
remember, go through the inventors guide and consider customizing the controller and using the jumpers first
if you dont NEED programming then $100 dollars down the drain
BTW if you do get a programming kit dont get MPLAB just get easyC because MPLAB can be really confusing to the beginner
