Our clawbot claw is not working properly, and we were told to remove the motor to see if that was the problem. However, we are unsure as to how to go about disassembling the claw enough to actually get the motor.
I’ve moved this to the general channel as it’s not related to ROBOTC.
its been quite a while since I touched a fully assembled claw, but you should be able to put a screwdriver through the bottom holes directly under the motor mount. the size of the head is 5/64, unscrew those two and your motor is out.
If your motor is stalling out, I think it may be something wrong with the claw itself. I have seen various teams using these claws with their motors stalling out very quickly.
