How to reset 3 wire bumper sensor
I am trying to make it so that I can reset my bumper sensors in between uses. Can anyone help.
def autonomous():
INERTIAL.set_heading(0, DEGREES)
INERTIAL.set_rotation(0, DEGREES)
INERTIAL.calibrate()
TOPROLLER.set_position(0, DEGREES)
BOTTOMROLLER.set_position(0, DEGREES)
LINTAKE.set_position(0, DEGREES)
RINTAKE.set_position(0, DEGREES)
RINTAKE.set_velocity(75, PERCENT)
LINTAKE.set_velocity(75, PERCENT)
TOPROLLER.set_velocity(75, PERCENT)
BOTTOMROLLER.set_velocity(75, PERCENT)
drivetrain.set_stopping(BRAKE)
drivetrain.set_velocity(100,PERCENT)
TOPROLLER.spin(FORWARD)
drivetrain.drive_for(FORWARD, 12, in)
drivetrain.turn_for(RIGHT, 90, DEGREES)
drivetrain.set_stopping(COAST)
Superspit
if SHOOTER.released(2)
else StopR
if MAGAZINE.pressed(3)
else drivetrain.drive_for(REVERSE,6,in)
Superspit
drivetrain.turn_for(RIGHT,110,DEGREES)
drivetrain.drive_for(FORWARD,96,in)
drivetrain.turn_for(LEFT,60,DEGREES)
drivetrain.drive_for(FORWARD, 6, in)
Superspit
else StopR
return
Bumper sensors are digital sensors, not analog sensors. If i recall correctly, their value should be 1 when pushed in, and changed back to 0 when you move away.
You can also reverse them like any other sensor if the situation requires it.
Isn’t that digital, in that it returns one of two states, true or false?
