I have two 1:1 gear ratio for front wheels in order to shift motors back a bit to make space, but after I reversed the motors, well it drives forward and back but the turns are fighting each other, if set back to default chassis the drive is fighting again.
the most optimal solution I have is have 1:1 gear ratio for back wheels too but my teacher insisted to use the code to solve the issue.
Plz help
