We have our tournament in 2 days, and in 2 days we’ve blown out 2 motors, so we cannot practice in case we blow out ANOTHER motor. Ours are two years old, so lol. I have two different drive codes: one that’s normal and one in reverse. I can switch between the two with two buttons. But then I tried to add a new drive code switcher using integers: 1 for normal, 2 for reverse, 3 for precision. for some reason it didn’t work at all. I then tried an AND gate with booleans: it runs, but for some reason it doesn’t actually read controller input? I don’t understand this at all. I’m away from my computer rn, but when I do get it I’ll send all the code for it. Can any of you think of a way to switch drive code, or done it yourself?
Can you post your code? That helps us a great deal. If posting text code please place it between two sets of ``` (three ticks in the keyboard upper left). If posting blocks then paste a screenshot.
I can’t post the code thst doesn’t work right now since I’m away from the computer, but I can post the one that DOES work. If you find a function called ‘ ’ ’bruhmoment();’ ’ ’ that’s how it works.
And I don’t see the reverse ‘ it must not be on iPad?
Good, descriptive function and variable names are important
Lmao you should see me in Unreal Engine
I’m thinking a Toffoli gate can work for this. I was kinda trying to code this anyways, just badly. It can convert booleans to integers.
That is a lot of code and it looks like a lot of repeat code which you will want to minimize.
Below is one concept. I created a chassisDirection
variable with a ReverseDirection
function. When you press the A button it will tell the chassisDirection
variable to reverse one time and then it sets the ReverseLatch
so the program doesn’t keep flipping Fwd/Rev every 20 ms.
You also don’t need the if > 0 or < 0 to determine direction. The controller sticks range from 100 to -100 so it automatically handles that.
directionType chassisDirection = directionType::fwd;
bool ReverseLatch = false;
void ReverseDirection(){
if(ReverseLatch) return;
ReverseLatch = true;
if(chassisDirection == fwd) {
chassisDirection = reverse;
return;
chassisDirection = fwd;
void DriveCode() {
int rightValue = static_cast <int>(pow(Controller1.Axis2.value(), 2)/50);
int leftValue = static_cast <int>(pow(Controller1.Axis3.value(), 2)/50);
leftSide.spin(chassisDirection, leftValue, pct);
rightSide.spin(chassisDirection, rightValue, pct);
void DriverControl(){
while(true){
DriveCode();
if(Controller1.ButtonA.pressing()){
ReverseDirection();
} else {
Doesn’t seem necessary here. A simpler solution would be a switch statement.
https://en.cppreference.com/w/cpp/language/switch
So in a switch statement, i would increase every time I click the button?
Btw I made the toffoli gate work, with some help of a teacher who knows c++
If you made it work, you should probably just keep it. But here’s how you would do it with a switch
int driveMode = 0; //this variable stores the current mode
void changeDriveMode(){
driveMode++; //increase the driveMode
if(driveMode > 2) driveMode = 0; //but if it becomes too large, reset it to 0
void driverControl(){
Controller.ButtonA.pressed(changeDriveMode);
while(true){
switch(driveMode){
case 0:{
//put code for mode 1 here
} break;
case 1:{
//put code for mode 2 here
} break;
case 2:{
//put code for mode 3 here
} break;
thank you. it luckily works the way i want it to
