How to use button.released?
I’m confused as to how to use the button.released command, like is it a check like how button.pressing works? How’d i implement it into my code. I need it because a button check is checking right after it was pressed and i want the code to wait until the button is no longer pressed.
released() function takes another function as a parameter. When ever the button gets released it calls that function once. It would be used like this…
void buttonARel()
    //button A was released: do stuff
vex::controller Controller1(vex::primary);
int main()
    Controller1.ButtonA.released(buttonARel);
    //do stuff
Alternative if you don’t want to use this you can do something like this…
bool buttonAState = false;
int main()
    while(true)
        if(!Controller1.ButtonA.pressing() && buttonAState)
        if(Controller1.ButtonA.pressing()) buttonAState = true
       //do stuff
Advanced way of doing it...
    0 = unpressed
    1 = first press cycle
    2 = pressed
    3 = first unpress cycle
int btnA = 2;
int main()
    while(true)
        if(btnA != (Controller1.ButtonA.pressing() * 2)) btnA = (btnA + 1) % 4;
        if(btnA == 3)
       //do stuff
Both of these achieve the same exact thing
ok thanks! this should come in handy
